跳转到主内容
OnePlus 2 Charging Port Replacement
你所需要的
  1. OnePlus 2 Charging Port Replacement, SIM Card: 步骤 1 中的图像 1,3 OnePlus 2 Charging Port Replacement, SIM Card: 步骤 1 中的图像 2,3 OnePlus 2 Charging Port Replacement, SIM Card: 步骤 1 中的图像 3,3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Charging Port Replacement: 步骤 2 中的图像 1,3 OnePlus 2 Charging Port Replacement: 步骤 2 中的图像 2,3 OnePlus 2 Charging Port Replacement: 步骤 2 中的图像 3,3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Remove the SIM card tray
  4. OnePlus 2 Charging Port Replacement, Battery: 步骤 4 中的图像 1,3 OnePlus 2 Charging Port Replacement, Battery: 步骤 4 中的图像 2,3 OnePlus 2 Charging Port Replacement, Battery: 步骤 4 中的图像 3,3
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Charging Port Replacement: 步骤 5 中的图像 1,3 OnePlus 2 Charging Port Replacement: 步骤 5 中的图像 2,3 OnePlus 2 Charging Port Replacement: 步骤 5 中的图像 3,3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Charging Port Replacement: 步骤 6 中的图像 1,3 OnePlus 2 Charging Port Replacement: 步骤 6 中的图像 2,3 OnePlus 2 Charging Port Replacement: 步骤 6 中的图像 3,3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
  7. OnePlus 2 Charging Port Replacement, Charging Port: 步骤 7 中的图像 1,2 OnePlus 2 Charging Port Replacement, Charging Port: 步骤 7 中的图像 2,2
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
  8. OnePlus 2 Charging Port Replacement: 步骤 8 中的图像 1,3 OnePlus 2 Charging Port Replacement: 步骤 8 中的图像 2,3 OnePlus 2 Charging Port Replacement: 步骤 8 中的图像 3,3
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
  9. OnePlus 2 Charging Port Replacement: 步骤 9 中的图像 1,3 OnePlus 2 Charging Port Replacement: 步骤 9 中的图像 2,3 OnePlus 2 Charging Port Replacement: 步骤 9 中的图像 3,3
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
结论
21等其他人完成本指南。
Kayla Williams
于10/01/15注册
1,541 声望
创作了6篇指南
团队
Cal Poly, Team 4-5, Maness Fall 2015 Cal Poly, Team 4-5, Maness Fall 2015 的会员
CPSU-MANESS-F15S4G5
4 名成员
创作了19篇指南
9条评论
How do you get the replacement USB type c port?
Ben King - 回复
I need it. If you can help
Mamdouh -
I need that part please. I need to buy it my phone stoped charging and need charging port with it's falt cable.. Please help me
My email is :mamdouh1978@gmail.com
Mamdouh - 回复
I need this part also. You can help me, please?
Enric Fransoy -
can you tell me why 2 pins on Charigng Port Flex ?? can I add wireless charger from it? please reply at atulmits@gmail.com
Atul Mandal - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 15,642
