简介
Follow this step-by-step guide to replace the motherboard of your OneLink Safe and Sound.
你所需要的
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
Use the opening tool to disconnect the speaker cables from the daughterboard.
Use the opening to lift the daughterboard off of the motherboard.
结论
