跳转到主内容
OneLink Safe and Sound Battery Replacement
你所需要的
  1. OneLink Safe and Sound Battery Replacement, Cover: 步骤 1 中的图像 1,2 OneLink Safe and Sound Battery Replacement, Cover: 步骤 1 中的图像 2,2
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Battery Replacement: 步骤 2 中的图像 1,2 OneLink Safe and Sound Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Battery Replacement: 步骤 3 中的图像 1,2 OneLink Safe and Sound Battery Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Battery Replacement: 步骤 4 中的图像 1,1
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Battery Replacement: 步骤 5 中的图像 1,2 OneLink Safe and Sound Battery Replacement: 步骤 5 中的图像 2,2
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to disconnect the cable from the motherboard.
  7. OneLink Safe and Sound Battery Replacement: 步骤 7 中的图像 1,2 OneLink Safe and Sound Battery Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
  8. OneLink Safe and Sound Battery Replacement: 步骤 8 中的图像 1,2 OneLink Safe and Sound Battery Replacement: 步骤 8 中的图像 2,2
    • Remove the plastic cage holding the battery in place.
    • Remove the battery from the device.
结论
2等其他人完成本指南。
Arianna Roberts
于11/10/22注册
657 声望
创作了6篇指南
团队
UMass Dartmouth, Team 2-2, Petersen Fall 2022 UMass Dartmouth, Team 2-2, Petersen Fall 2022 的会员
UMASSD-PETERSEN-F22S2G2
3 名成员
创作了6篇指南
5指南评论
Where do I get this battery replacement
Dallas Massey - 回复
people that has purchased this product. If the battery goes dead where can someone purchase a replacement battery from and what size battery would they need
Pamela Wright - 回复
Is there a P/N for the battery pack or it needs to be bought individually and then put together
Thank you
Jose Chocano Felice - 回复
Bought a 2CR17335A-WK17 battery pack from Amazon for $15 plus tax. Just had to splice wires to existing connector to match the motherboard. So far so good. Had a 5 chirp tone every 2 minutes advising battery had come to end of life. Not sure why a 10 year battery only lasted 3 years from the manufacturing date but oh well.
Mario Garcia - 回复
Bought this on Amazon. Soldered the cable from the old battery to the new one and everything works good as new :)
SHENYANG MR-BAT6V1 2CR17335A WK17 6V 1800mAh Battery with Plug for Mitsubishi CNC https://a.co/d/4PbtZJK
Johnny Sutherland - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 69
总计 3,000
