跳转到主内容
One Education Infinity:One Hinge Contact Assembly Replacement
你所需要的
  1. One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 步骤 1 中的图像 1,2 One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 步骤 1 中的图像 2,2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 2 中的图像 1,2 One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 2 中的图像 2,2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 4 中的图像 1,2 One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 步骤 5 中的图像 1,2 One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 步骤 5 中的图像 2,2
    • Lift the hinge away from the device.
  6. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the two 6.5mm screws.
  7. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 7 中的图像 1,2 One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 7 中的图像 2,2
    • Slide a Jimmy or other prying tool along the seam of the hinge to pry the casing apart.
  8. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 8 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 4.3mm screws holding the circuit board in place.
  9. One Education Infinity:One Hinge Contact Assembly Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to pry the circuit board away from the casing.
    • Always use ESD safe tools when removing delicate components.
结论
Taylor Bratsch
于09/06/16注册
6,089 声望
创作了14篇指南
1指南评论
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
Nathan Joyce - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 296
