跳转到主内容
One Education Infinity:One Battery Replacement
你所需要的
  1. One Education Infinity:One Battery Replacement, Top Case: 步骤 1 中的图像 1,3 One Education Infinity:One Battery Replacement, Top Case: 步骤 1 中的图像 2,3 One Education Infinity:One Battery Replacement, Top Case: 步骤 1 中的图像 3,3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: 步骤 2 中的图像 1,2 One Education Infinity:One Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: 步骤 3 中的图像 1,3 One Education Infinity:One Battery Replacement: 步骤 3 中的图像 2,3 One Education Infinity:One Battery Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: 步骤 4 中的图像 1,3 One Education Infinity:One Battery Replacement: 步骤 4 中的图像 2,3 One Education Infinity:One Battery Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: 步骤 5 中的图像 1,1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
结论
另外一个人完成了本指南。
Taylor Bratsch
于09/06/16注册
6,089 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,131
