跳转到主内容
One Education Infinity:One Antenna Prerequisite
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. One Education Infinity:One Antenna Prerequisite, Battery: 步骤 1 中的图像 1,2 One Education Infinity:One Antenna Prerequisite, Battery: 步骤 1 中的图像 2,2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Antenna Prerequisite: 步骤 2 中的图像 1,3 One Education Infinity:One Antenna Prerequisite: 步骤 2 中的图像 2,3 One Education Infinity:One Antenna Prerequisite: 步骤 2 中的图像 3,3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Antenna Prerequisite: 步骤 3 中的图像 1,3 One Education Infinity:One Antenna Prerequisite: 步骤 3 中的图像 2,3 One Education Infinity:One Antenna Prerequisite: 步骤 3 中的图像 3,3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Antenna Prerequisite: 步骤 4 中的图像 1,1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Antenna Prerequisite, Antenna: 步骤 5 中的图像 1,2 One Education Infinity:One Antenna Prerequisite, Antenna: 步骤 5 中的图像 2,2
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
结论
Taylor Bratsch
于09/06/16注册
5,742 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 45
