跳转到主内容
One Education Infinity One Touchpad Replacement
你所需要的
  1. One Education Infinity One Touchpad Replacement, Back Case: 步骤 1 中的图像 1,2 One Education Infinity One Touchpad Replacement, Back Case: 步骤 1 中的图像 2,2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity One Touchpad Replacement: 步骤 2 中的图像 1,2 One Education Infinity One Touchpad Replacement: 步骤 2 中的图像 2,2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity One Touchpad Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity One Touchpad Replacement: 步骤 4 中的图像 1,2 One Education Infinity One Touchpad Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity One Touchpad Replacement, Daughterboard: 步骤 5 中的图像 1,2 One Education Infinity One Touchpad Replacement, Daughterboard: 步骤 5 中的图像 2,2
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity One Touchpad Replacement: 步骤 6 中的图像 1,2 One Education Infinity One Touchpad Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity One Touchpad Replacement: 步骤 7 中的图像 1,3 One Education Infinity One Touchpad Replacement: 步骤 7 中的图像 2,3 One Education Infinity One Touchpad Replacement: 步骤 7 中的图像 3,3
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
  8. One Education Infinity One Touchpad Replacement, Keyboard Frame Prerequisite: 步骤 8 中的图像 1,2 One Education Infinity One Touchpad Replacement, Keyboard Frame Prerequisite: 步骤 8 中的图像 2,2
    • Use a spudger to lift up the black retaining flap on the touchpad's ZIF connector.
    • Pull the ribbon cable straight back to remove.
  9. One Education Infinity One Touchpad Replacement: 步骤 9 中的图像 1,1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws holding the touchpad in place.
  10. One Education Infinity One Touchpad Replacement: 步骤 10 中的图像 1,2 One Education Infinity One Touchpad Replacement: 步骤 10 中的图像 2,2
    • Feed the ribbon cable through the hole in the metal frame.
    • Left the metal frame away from the device.
  11. One Education Infinity One Touchpad Replacement, Touchpad: 步骤 11 中的图像 1,2 One Education Infinity One Touchpad Replacement, Touchpad: 步骤 11 中的图像 2,2
    • Use a spudger to pry the touchpad away from the device.
结论
Taylor Bratsch
于09/06/16注册
6,083 声望
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 325
