跳转到主内容
One Education Infinity Motherboard Replacement
你所需要的
  1. One Education Infinity Motherboard Replacement, Back Case: 步骤 1 中的图像 1,3 One Education Infinity Motherboard Replacement, Back Case: 步骤 1 中的图像 2,3 One Education Infinity Motherboard Replacement, Back Case: 步骤 1 中的图像 3,3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Motherboard Replacement: 步骤 2 中的图像 1,2 One Education Infinity Motherboard Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Motherboard Replacement: 步骤 3 中的图像 1,3 One Education Infinity Motherboard Replacement: 步骤 3 中的图像 2,3 One Education Infinity Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Motherboard Replacement, Battery: 步骤 4 中的图像 1,3 One Education Infinity Motherboard Replacement, Battery: 步骤 4 中的图像 2,3 One Education Infinity Motherboard Replacement, Battery: 步骤 4 中的图像 3,3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Motherboard Replacement: 步骤 5 中的图像 1,3 One Education Infinity Motherboard Replacement: 步骤 5 中的图像 2,3 One Education Infinity Motherboard Replacement: 步骤 5 中的图像 3,3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Motherboard Replacement, Solid State Drive: 步骤 6 中的图像 1,3 One Education Infinity Motherboard Replacement, Solid State Drive: 步骤 6 中的图像 2,3 One Education Infinity Motherboard Replacement, Solid State Drive: 步骤 6 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Motherboard Replacement: 步骤 7 中的图像 1,3 One Education Infinity Motherboard Replacement: 步骤 7 中的图像 2,3 One Education Infinity Motherboard Replacement: 步骤 7 中的图像 3,3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
  8. One Education Infinity Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 One Education Infinity Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
  9. One Education Infinity Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
  10. One Education Infinity Motherboard Replacement: 步骤 10 中的图像 1,1
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
  11. One Education Infinity Motherboard Replacement: 步骤 11 中的图像 1,1
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
  12. One Education Infinity Motherboard Replacement: 步骤 12 中的图像 1,2 One Education Infinity Motherboard Replacement: 步骤 12 中的图像 2,2
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
  13. One Education Infinity Motherboard Replacement: 步骤 13 中的图像 1,1
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
  14. One Education Infinity Motherboard Replacement: 步骤 14 中的图像 1,2 One Education Infinity Motherboard Replacement: 步骤 14 中的图像 2,2
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
结论
Bowie Wood
于10/10/19注册
295 声望
撰写一个指南
团队
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 的会员
CPSU-PATON-S20S7G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 5
总计 188
