简介
In this guide you will learn how to replace the handle of your One Education Infinity. The handle is connected to the lower case with springs and Phillips #00 screws so it has give but is very secure. In the event that the handle becomes damaged, the process is very easy to replace. Be sure to power off and unplug your laptop prior to doing any work on your laptop, even the handle.
你所需要的
Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
Using the Phillips #00, remove the two 4.7 mm screws securing the handle to the case.
