跳转到主内容
Onda VI10 Screen Replacement
你所需要的
  1. Onda VI10  Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Remove four Phillips head screws from back with #0 screw driver.
  2. Onda VI10  Screen Replacement: 步骤 2 中的图像 1,2 Onda VI10  Screen Replacement: 步骤 2 中的图像 2,2
    • Separate the back from the screen and open as shown. Make sure to open from the side with the power button to avoid damaging the ribbon cables.
  3. Onda VI10  Screen Replacement: 步骤 3 中的图像 1,1
    • Using the plastic spudger, lift the black latches for the ribbon cables and slide the cables out of their sockets. Now the two halves can be separated.
  4. Onda VI10  Screen Replacement: 步骤 4 中的图像 1,1
    • There are 14 3mm long screws surrounding the screen. Using the #00 Phillips screwdriver, remove all of these screws.
  5. Onda VI10  Screen Replacement: 步骤 5 中的图像 1,1
    • Using the metal spudger, depress the four plastic tabs to free the glass from the display.
  6. Onda VI10  Screen Replacement: 步骤 6 中的图像 1,1
    • Use the metal spudger again to get between the glass and the chrome trim ring. Lightly pry the glass away from the display. If this proves difficult, double check that all of the screws have been removed and that all four plastic clips are pushed in. Again, start from the side opposite the ribbon cable to avoid damaging it.
  7. Onda VI10  Screen Replacement: 步骤 7 中的图像 1,1
    • Once the glass and display have been separated, pull the glass away from the display and carefully slide the ribbon cable out of the display housing.
结论
Solomon Hunter
于03/08/17注册
101 声望
撰写一个指南
团队
IUPUI, Team S4-G3, Baechle Spring 2017 IUPUI, Team S4-G3, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S4G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 275
