跳转到主内容
Onda V701 Battery Replacement
你所需要的
  1. Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 1,3 Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 2,3 Onda V701 Battery Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Battery Replacement: 步骤 2 中的图像 1,3 Onda V701 Battery Replacement: 步骤 2 中的图像 2,3 Onda V701 Battery Replacement: 步骤 2 中的图像 3,3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Battery Replacement: 步骤 3 中的图像 1,2 Onda V701 Battery Replacement: 步骤 3 中的图像 2,2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Battery Replacement: 步骤 4 中的图像 1,2 Onda V701 Battery Replacement: 步骤 4 中的图像 2,2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Battery Replacement: 步骤 5 中的图像 1,3 Onda V701 Battery Replacement: 步骤 5 中的图像 2,3 Onda V701 Battery Replacement: 步骤 5 中的图像 3,3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Desolder the red(+) and black(-) wires connecting the battery to the motherboard using a soldering iron and tweezers to hold the wire.
    • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
  7. Onda V701 Battery Replacement: 步骤 7 中的图像 1,3 Onda V701 Battery Replacement: 步骤 7 中的图像 2,3 Onda V701 Battery Replacement: 步骤 7 中的图像 3,3
    • Carefully pry the battery away from the back panel using the nylon or metal spudger.
    • Gently remove the battery from the back panel.
    • Ensure not to excessively bend or puncture the battery. Doing so could cause the battery to catch on fire or explode.
结论
另外一个人完成了本指南。
Bradley Huber
于03/11/15注册
366 声望
创作了3篇指南
团队
Colorado Springs, Team 4-6, Panko Spring 2015 Colorado Springs, Team 4-6, Panko Spring 2015 的会员
UCCS-PANKO-S15S4G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 857
