当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
Use a magnet to remove the screws after unscrewing them and place them aside.
Carefully remove the back cover without breaking the battery wire.
Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
The battery is still attached to the back cover.
Remove the mic wire by carefully pulling the plug out of the socket.
Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
Remove the screws using the screwdriver.
Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
Carefully remove the motherboard with your hand by lifting it from the device.
Separate the port cover from the device using your hands.
Orient the device so the port cover is on your left.
Using Tweezers, pinch the larger part of the stem
Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
取消:我没有完成这个指南。
2等其他人完成本指南。
与4其他贡献者
于02/17/16注册
119 声望
撰写一个指南
徽章: 6
+ 3更多徽章
USFT-SULLIVAN-S16S2G2
3 名成员
创作了2篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 12
总计 377
