跳转到主内容
Omaker M4 Port Cover Replacement
你所需要的
  1. Omaker M4 Port Cover Replacement, Back Case: 步骤 1 中的图像 1,1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Port Cover Replacement: 步骤 2 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Port Cover Replacement: 步骤 3 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 3 中的图像 2,2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Port Cover Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Port Cover Replacement: 步骤 5 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 5 中的图像 2,2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Port Cover Replacement, Motherboard: 步骤 6 中的图像 1,2 Omaker M4 Port Cover Replacement, Motherboard: 步骤 6 中的图像 2,2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Port Cover Replacement: 步骤 7 中的图像 1,1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Port Cover Replacement: 步骤 8 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 8 中的图像 2,2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Port Cover Replacement: 步骤 9 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 9 中的图像 2,2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Port Cover Replacement: 步骤 10 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 10 中的图像 2,2
    • Carefully remove the motherboard with your hand by lifting it from the device.
  11. Omaker M4 Port Cover Replacement, Port Cover: 步骤 11 中的图像 1,2 Omaker M4 Port Cover Replacement, Port Cover: 步骤 11 中的图像 2,2
    • Separate the port cover from the device using your hands.
  12. Omaker M4 Port Cover Replacement: 步骤 12 中的图像 1,1
    • Orient the device so the port cover is on your left.
  13. Omaker M4 Port Cover Replacement: 步骤 13 中的图像 1,2 Omaker M4 Port Cover Replacement: 步骤 13 中的图像 2,2
    • Using Tweezers, pinch the larger part of the stem
  14. Omaker M4 Port Cover Replacement: 步骤 14 中的图像 1,1
    • Use your left hand to pull while at the same time use the tweezers to compress the stem, carefully remove the port cover from the device.
结论
2等其他人完成本指南。
Obaida Matar
于02/17/16注册
119 声望
撰写一个指南
团队
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G2
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 365
