跳转到主内容
简介
When using the metal spudger to remove the battery, be sure to carefully pry along the entire side the battery so that the battery will come off without bending.
  1. Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device. Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Use a magnet to remove the screws after unscrewing them and place them aside. Use a magnet to remove the screws after unscrewing them and place them aside.
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Carefully remove the back cover without breaking the battery wire.
    • Carefully remove the back cover without breaking the battery wire.
  5. Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers. The battery is still attached to the back cover.
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover. Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
结论
3等其他人完成本指南。
Carlos Pernia
于2016年02月10日注册
170 信誉积分
撰写一个指南
团队
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G2
3 名成员
创作了2篇指南
一条评论
What battery is required for this though? Is it easily found on amazon?
Mohsin - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 8
总计 1,096
