跳转到主内容
Omaker M4 Battery Replacement
你所需要的
  1. Omaker M4 Battery Replacement, Back Case: 步骤 1 中的图像 1,1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: 步骤 2 中的图像 1,2 Omaker M4 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: 步骤 3 中的图像 1,2 Omaker M4 Battery Replacement: 步骤 3 中的图像 2,2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: 步骤 5 中的图像 1,2 Omaker M4 Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: 步骤 6 中的图像 1,3 Omaker M4 Battery Replacement, Battery: 步骤 6 中的图像 2,3 Omaker M4 Battery Replacement, Battery: 步骤 6 中的图像 3,3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
结论
3等其他人完成本指南。
Carlos Pernia
于02/10/16注册
170 声望
撰写一个指南
团队
USF Tampa, Team 2-2, Sullivan Spring 2016 USF Tampa, Team 2-2, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S2G2
3 名成员
创作了2篇指南
一条评论
What battery is required for this though? Is it easily found on amazon?
Mohsin - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 1,325
