本指南有最近更改,您可查看未经巡查的最新版本。
简介
Removing the back case from the speaker is relatively easy. Once you unscrew the four back screws, there is a wire that is attached to the back case. Before pulling the back case completely off, disconnect the wire from the back case by carefully pulling it out with tweezers. This will allow the back case to be completely removed from the device.
你所需要的
Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
3等其他人完成本指南。
