跳转到主内容
Olympus Tough TG-1 Screen Replacement
你所需要的
  1. Olympus Tough TG-1 Screen Replacement, Clip Side Repair: 步骤 1 中的图像 1,2 Olympus Tough TG-1 Screen Replacement, Clip Side Repair: 步骤 1 中的图像 2,2
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Screen Replacement, Top of Camera: 步骤 2 中的图像 1,1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Screen Replacement, Plug Side: 步骤 3 中的图像 1,3 Olympus Tough TG-1 Screen Replacement, Plug Side: 步骤 3 中的图像 2,3 Olympus Tough TG-1 Screen Replacement, Plug Side: 步骤 3 中的图像 3,3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Screen Replacement, Bottom: 步骤 4 中的图像 1,1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Screen Replacement, Front Panel: 步骤 5 中的图像 1,3 Olympus Tough TG-1 Screen Replacement, Front Panel: 步骤 5 中的图像 2,3 Olympus Tough TG-1 Screen Replacement, Front Panel: 步骤 5 中的图像 3,3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 步骤 6 中的图像 1,3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 步骤 6 中的图像 2,3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: 步骤 6 中的图像 3,3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 步骤 7 中的图像 1,3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 步骤 7 中的图像 2,3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: 步骤 7 中的图像 3,3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Screen Replacement, Unclipping the Screen from the Circuit Ribbon: 步骤 8 中的图像 1,1
    • Carefully unclip the screen from its circuit ribbon.
结论
Emily Gensch
于01/21/15注册
116 声望
撰写一个指南
团队
USF Tampa, Team 4-6, Brown Winter 2015 USF Tampa, Team 4-6, Brown Winter 2015 的会员
USFT-BROWN-W15S4G6
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 20
总计 2,323
