跳转到主内容
Olympus TG-820 iHS Top Buttons Replacement
你所需要的
  1. Olympus TG-820 iHS Top Buttons Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Top Buttons Replacement: 步骤 2 中的图像 1,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 2 中的图像 2,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 2 中的图像 3,3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Top Buttons Replacement: 步骤 3 中的图像 1,2 Olympus TG-820 iHS Top Buttons Replacement: 步骤 3 中的图像 2,2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Top Buttons Replacement, Back Case: 步骤 4 中的图像 1,1
    • Orient the camera so you are looking at the bottom.
    • Remove the three 3.85mm Phillips #00 screws from the bottom of the camera.
  5. Olympus TG-820 iHS Top Buttons Replacement: 步骤 5 中的图像 1,1
    • Orient the camera so you are looking at the side plate.
    • Remove the two 3.15mm Phillips #00 screws from the side plate of the camera.
  6. Olympus TG-820 iHS Top Buttons Replacement: 步骤 6 中的图像 1,2 Olympus TG-820 iHS Top Buttons Replacement: 步骤 6 中的图像 2,2
    • Orient the camera so you are looking at the front plate.
    • Remove the two 3.8mm with the Phillips H1.5 from the front plate.
    • Remove the "Olympus" plate.
  7. Olympus TG-820 iHS Top Buttons Replacement: 步骤 7 中的图像 1,1
    • Remove face plate.
  8. Olympus TG-820 iHS Top Buttons Replacement: 步骤 8 中的图像 1,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 8 中的图像 2,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 8 中的图像 3,3
    • Locate three small black screws inside of the battery compartment.
    • Remove the 3.85mm Phillips #00 screw on the far left side.
    • Remove the two 5mm Phillips #00 screws on the right side
  9. Olympus TG-820 iHS Top Buttons Replacement: 步骤 9 中的图像 1,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 9 中的图像 2,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 9 中的图像 3,3
    • Orient the camera to be look at the top.
    • Remove the 5.4mm Phillips #00 screw on the top left side.
    • Remove the 7.4mm Phillips #00 screw next to the "ON/OFF" label.
    • Pry off top button plate with black nylon spudger.
  10. Olympus TG-820 iHS Top Buttons Replacement: 步骤 10 中的图像 1,2 Olympus TG-820 iHS Top Buttons Replacement: 步骤 10 中的图像 2,2
    • Rotate to bottom of camera and locate bottom latch.
    • Wedge black nylon spudger in between bottom latch and camera base to release LCD Screen from camera.
    • Push firmly apart.
    • Some buttons might fall out.
  11. Olympus TG-820 iHS Top Buttons Replacement: 步骤 11 中的图像 1,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 11 中的图像 2,3 Olympus TG-820 iHS Top Buttons Replacement: 步骤 11 中的图像 3,3
    • Orient the camera to the LCD screen side that is now wedged open.
    • Locate the white ribbon cable and pull out from motherboard.
    • Locate the brown ribbon cable and pull out from motherboard.
  12. Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: 步骤 12 中的图像 1,3 Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: 步骤 12 中的图像 2,3 Olympus TG-820 iHS Top Buttons Replacement, Top Buttons: 步骤 12 中的图像 3,3
    • Remove the two 3mm Phillips #00 screws.
    • Remove the one small black 2mm Phillips #00 screw.
    • Remove silver button plate from camera base.
    • Buttons may come loose
结论
Larissa Knight
于03/21/16注册
549 声望
创作了5篇指南
团队
Clemson, Team 7-2, Benson Spring 2016 Clemson, Team 7-2, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G2
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 749
