跳转到主内容
Olympus Stylus Tough-8010 Side Panel Replacement
你所需要的
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 步骤 1 中的图像 1,3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 步骤 1 中的图像 2,3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: 步骤 1 中的图像 3,3
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 2 中的图像 1,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 2 中的图像 2,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 2 中的图像 3,3
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 3 中的图像 1,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 3 中的图像 2,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 3 中的图像 3,3
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 4 中的图像 1,2 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 4 中的图像 2,2
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 5 中的图像 1,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 5 中的图像 2,3 Olympus Stylus Tough-8010 Side Panel Replacement: 步骤 5 中的图像 3,3
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
结论
James G Payne
于03/23/15注册
225 声望
创作了2篇指南
团队
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G15
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 361
