简介
Use this guide if you need to replace your Olympus Stylus Tough-8010 camera's LCD screen.
你所需要的
Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
Take off smaller front cover.
Carefully remove larger front cover.
在这个步骤中使用的工具:Tweezers$4.99
Remove four screws (9.4mm) on the front of the camera using a Phillips #000
Use the plastic opening tool to release the holding clip.
Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
Remove all the tape and clear rubber material from the components.
Remove two screws (4.1mm) using a #000 Phillips head screwdriver on the left side of the lcd component.
Using the tweezers disconnect the plastic ribbon from the connector on the control board by lifting the small black flap on the connector and pulling on the ribbon.
