跳转到主内容
Olympus Stylus Tough-8010 Battery Replacement
  1. Olympus Stylus Tough-8010 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the side panel that allows access to the battery by turning the circular lock mechanism counterclockwise.
    • Slide the locking mechanism up. You should see red when the camera is unlocked.
  2. Olympus Stylus Tough-8010 Battery Replacement: 步骤 2 中的图像 1,1
    • Open the side panel and check for any obstructions in the battery slot.
    • Insert the battery in the correct orientation in the battery slot.
结论
James G Payne
于03/23/15注册
225 声望
创作了2篇指南
团队
Baylor, Team 7-15, Williams Spring 2015 Baylor, Team 7-15, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G15
3 名成员
创作了12篇指南
一条评论
i can’t open the battery door
Kayla Chatman - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 9
总计 1,013
