跳转到主内容
Olympus Stylus Tough-6000 On/Off Button Replacement
你所需要的
  1. Olympus Stylus Tough-6000 On/Off Button Replacement, Locate On/Off Button.: 步骤 1 中的图像 1,1
    • First sit the camera on its bottom. You will be working on the on/off button.
  2. Olympus Stylus Tough-6000 On/Off Button Replacement: 步骤 2 中的图像 1,1
    • Place camera upward.
    • You will notice two screws near the on/off button.
    • Use your Phillips #00 screwdriver to unscrew the two screws.
  3. Olympus Stylus Tough-6000 On/Off Button Replacement: 步骤 3 中的图像 1,1
    • After unscrewing the two screws near the on/off button you will notice a single screw to your right.
    • Unscrew the single screw with your Phillips #00 screwdriver.
    • This will allow you to pry the panel off.
  4. Olympus Stylus Tough-6000 On/Off Button Replacement: 步骤 4 中的图像 1,1
    • Grab your plastic opening tool and start prying off the panel.
  5. Olympus Stylus Tough-6000 On/Off Button Replacement: 步骤 5 中的图像 1,1
    • Once the panel is lifted you will want to lift up the cover for the on/off button.
    • The actual on/off button is very small and loose so make sure to be careful with it!
  6. Olympus Stylus Tough-6000 On/Off Button Replacement: 步骤 6 中的图像 1,1
    • You have reached the on/off button.
    • You can now replace it!
结论
另外一个人完成了本指南。
Shannon Cooney
于01/15/15注册
355 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 568
