跳转到主内容
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
你所需要的
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 步骤 1 中的图像 1,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 步骤 1 中的图像 2,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: 步骤 1 中的图像 3,3
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 2 中的图像 1,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 2 中的图像 2,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 2 中的图像 3,3
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 3 中的图像 1,2 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 3 中的图像 2,2
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 4 中的图像 1,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 4 中的图像 2,3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: 步骤 4 中的图像 3,3
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
结论
另外一个人完成了本指南。
3条评论
Where can I get the seals?
Ahmed - 回复
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - 回复
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 2,092
