跳转到主内容
Olympus Stylus Tough 6020 Motherboard Replacement
你所需要的
  1. Olympus Stylus Tough 6020 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: 步骤 2 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: 步骤 2 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, Bottom Plating: 步骤 2 中的图像 3,3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: 步骤 3 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: 步骤 3 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, Top Plating: 步骤 3 中的图像 3,3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 Motherboard Replacement, Left Plating: 步骤 4 中的图像 1,2 Olympus Stylus Tough 6020 Motherboard Replacement, Left Plating: 步骤 4 中的图像 2,2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: 步骤 5 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: 步骤 5 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, Black "Olympus" Face Plate: 步骤 5 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: 步骤 6 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: 步骤 6 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, End Casing: 步骤 6 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: 步骤 7 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: 步骤 7 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, Blue Face Plate: 步骤 7 中的图像 3,3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 Motherboard Replacement, Back Plate: 步骤 8 中的图像 1,1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 9 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 9 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 Motherboard Replacement, Ribbon Cables: 步骤 10 中的图像 1,1
    • Using tweezers, disconnect the white ribbon cable from the motherboard.
    • Using tweezers, disconnect the brown ribbon cable from the motherboard.
  11. Olympus Stylus Tough 6020 Motherboard Replacement, Metal Panel: 步骤 11 中的图像 1,1
    • Using a screwdriver, unscrew the four screws off of the center metal panel.
    • Using tweezers, disconnect the ribbon cable from the motherboard.
    • Using tweezers, remove the metal panel.
  12. Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement, Motherboard: 步骤 12 中的图像 3,3
    • Using a screwdriver, unscrew the black screw on the top left of the motherboard.
    • Using a screwdriver, unscrew the screw on the bottom left of the motherboard.
    • Using tweezers, disconnect the ribbon cable on the top right of the motherboard.
    • Using tweezers, disconnect the ribbon cable on the bottom right of the motherboard.
    • Using a spudger, pry the motherboard up.
  13. Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 13 中的图像 1,3 Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 13 中的图像 2,3 Olympus Stylus Tough 6020 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Using a soldering iron, desolder the red and white cables that are connected to the motherboard.
    • Using a soldering iron, desolder the blue wire on the back of the motherboard.
结论
另外一个人完成了本指南。
一条评论
I can no longer say "Youth is wasted on the young" Thanks
Edward Williams - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 587
