跳转到主内容
Olympus Stylus 760 LCD Screen Replacement
你所需要的
  1. Olympus Stylus 760 LCD Screen Replacement, Battery door: 步骤 1 中的图像 1,1
    • Slide the door located on the bottom of the camera in an outward direction
  2. Olympus Stylus 760 LCD Screen Replacement, Release: 步骤 2 中的图像 1,1
    • Pull back on the red release tab located on the left side of the battery.
  3. Olympus Stylus 760 LCD Screen Replacement, Replacement: 步骤 3 中的图像 1,1
    • Slide battery out of camera
  4. Olympus Stylus 760 LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,1
    • Remove the 2 screws from the bottom of the camera
  5. Olympus Stylus 760 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips head size 0 screwdriver, remove the screw from the right side of the camera
  6. Olympus Stylus 760 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the 2 screws from the left side of the camera
  7. Olympus Stylus 760 LCD Screen Replacement: 步骤 7 中的图像 1,3 Olympus Stylus 760 LCD Screen Replacement: 步骤 7 中的图像 2,3 Olympus Stylus 760 LCD Screen Replacement: 步骤 7 中的图像 3,3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  8. Olympus Stylus 760 LCD Screen Replacement: 步骤 8 中的图像 1,2 Olympus Stylus 760 LCD Screen Replacement: 步骤 8 中的图像 2,2
    • Pull the silver bracket off of the camera
  9. Olympus Stylus 760 LCD Screen Replacement: 步骤 9 中的图像 1,3 Olympus Stylus 760 LCD Screen Replacement: 步骤 9 中的图像 2,3 Olympus Stylus 760 LCD Screen Replacement: 步骤 9 中的图像 3,3
    • Remove the 4 screws on the inner face of the camera.
    • Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  10. Olympus Stylus 760 LCD Screen Replacement: 步骤 10 中的图像 1,1
    • You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
  11. Olympus Stylus 760 LCD Screen Replacement: 步骤 11 中的图像 1,2 Olympus Stylus 760 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Remove 4 screws holding the LCD screen in place.
    • Be cautious of the brackets that come loose when you remove the 3 screws on the right side of the camera
    • LCD Screen is attached to 2 ribbon wires
  12. Olympus Stylus 760 LCD Screen Replacement: 步骤 12 中的图像 1,2 Olympus Stylus 760 LCD Screen Replacement: 步骤 12 中的图像 2,2
    • Pull up on the small ribbon wire to disconnect it from the circuit board
    • Flip the little black clip up to remove the larger ribbon wire from the circuit board.
  13. Olympus Stylus 760 LCD Screen Replacement: 步骤 13 中的图像 1,1
    • Using a plastic separating tool, remove the LCD screen from the plastic casing.
结论
另外一个人完成了本指南。
Ryan Cosgrove
于02/10/12注册
39 声望
撰写一个指南
团队
James Madison, Team 3-3, Klein Spring 2012 James Madison, Team 3-3, Klein Spring 2012 的会员
JMU-KLEIN-S12S3G3
4 名成员
创作了7篇指南
一条评论
from where i can get repaired u760 camera
tahir zafar - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 84
总计 1,629
