跳转到主内容
Olympus Stylus 725 SW Lens Replacement
你所需要的
  1. Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 1 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 1 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 1 中的图像 3,3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  2. Olympus Stylus 725 SW Lens Replacement: 步骤 2 中的图像 1,2 Olympus Stylus 725 SW Lens Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  3. Olympus Stylus 725 SW Lens Replacement, Front Panel: 步骤 3 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement, Front Panel: 步骤 3 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement, Front Panel: 步骤 3 中的图像 3,3
    • Remove the top screws using a 1.5 mm screwdriver.
    • Remove the single side screw located on the side of the camera where the tab is, using a #00 screwdriver.
  4. Olympus Stylus 725 SW Lens Replacement, Side Panels: 步骤 4 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement, Side Panels: 步骤 4 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement, Side Panels: 步骤 4 中的图像 3,3
    • Using a #00 Philips Head Screwdriver, remove the screws located on all four sides of the camera.
  5. Olympus Stylus 725 SW Lens Replacement: 步骤 5 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement: 步骤 5 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement: 步骤 5 中的图像 3,3
    • After removing all four of the screws, pry the side covers off of the camera.
  6. Olympus Stylus 725 SW Lens Replacement, Lens: 步骤 6 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement, Lens: 步骤 6 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement, Lens: 步骤 6 中的图像 3,3
    • Unscrew four 2mm long screws using the #00 Phillips screwdriver.
  7. Olympus Stylus 725 SW Lens Replacement: 步骤 7 中的图像 1,3 Olympus Stylus 725 SW Lens Replacement: 步骤 7 中的图像 2,3 Olympus Stylus 725 SW Lens Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove four metal tabs from corners where the 2mm long screws were attached using tweezers.
  8. Olympus Stylus 725 SW Lens Replacement: 步骤 8 中的图像 1,2 Olympus Stylus 725 SW Lens Replacement: 步骤 8 中的图像 2,2
    • Remove the viewfinder lens using a prying device.
    • There will be two ribbons attached to the viewfinder. Remove the ribbons by sliding them off the viewfinder with your thumb.
结论
Bobby Hodges
于04/18/10注册
49 声望
创作了6篇指南
团队
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G71
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 13
总计 4,477
