跳转到主内容
Olympus Stylus 725 SW LCD Screen Replacement
你所需要的
  1. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 1,2 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Battery: 步骤 1 中的图像 2,2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 1,3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 2,3 Olympus Stylus 725 SW LCD Screen Replacement, Disassembling Olympus Stylus 725 SW Back Panel: 步骤 2 中的图像 3,3
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Olympus Stylus 725 SW LCD Screen Replacement: 步骤 3 中的图像 1,2 Olympus Stylus 725 SW LCD Screen Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
  4. Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 1,3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 2,3 Olympus Stylus 725 SW LCD Screen Replacement, LCD Screen: 步骤 4 中的图像 3,3
    • Remove the screws in the back panel using a Phillips #00 screwdriver.
    • Detach the ribbon cables that connect the LCD to the back panel of the camera.
  5. Olympus Stylus 725 SW LCD Screen Replacement: 步骤 5 中的图像 1,2 Olympus Stylus 725 SW LCD Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove the loosened LCD screen.
    • Be careful to not scratch the new LCD screen when replacing it.
    • Carefully place the new screen in place of the old, making sure the label faces up.
结论
另外一个人完成了本指南。
Bobby Hodges
于04/18/10注册
49 声望
创作了6篇指南
团队
Cal Poly, Team 33-71, Johann Spring 2010 Cal Poly, Team 33-71, Johann Spring 2010 的会员
CPSU-JOHANN-S10S33G71
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 26
总计 8,022
