跳转到主内容
Olympus Stylus 410 Speaker Replacement
你所需要的
  1. Olympus Stylus 410 Speaker Replacement, Outer Case: 步骤 1 中的图像 1,3 Olympus Stylus 410 Speaker Replacement, Outer Case: 步骤 1 中的图像 2,3 Olympus Stylus 410 Speaker Replacement, Outer Case: 步骤 1 中的图像 3,3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Speaker Replacement: 步骤 2 中的图像 1,2 Olympus Stylus 410 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  3. Olympus Stylus 410 Speaker Replacement: 步骤 3 中的图像 1,2 Olympus Stylus 410 Speaker Replacement: 步骤 3 中的图像 2,2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  4. Olympus Stylus 410 Speaker Replacement: 步骤 4 中的图像 1,2 Olympus Stylus 410 Speaker Replacement: 步骤 4 中的图像 2,2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  5. Olympus Stylus 410 Speaker Replacement: 步骤 5 中的图像 1,3 Olympus Stylus 410 Speaker Replacement: 步骤 5 中的图像 2,3 Olympus Stylus 410 Speaker Replacement: 步骤 5 中的图像 3,3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  6. Olympus Stylus 410 Speaker Replacement: 步骤 6 中的图像 1,1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  7. Olympus Stylus 410 Speaker Replacement: 步骤 7 中的图像 1,2 Olympus Stylus 410 Speaker Replacement: 步骤 7 中的图像 2,2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  8. Olympus Stylus 410 Speaker Replacement, Speaker: 步骤 8 中的图像 1,3 Olympus Stylus 410 Speaker Replacement, Speaker: 步骤 8 中的图像 2,3 Olympus Stylus 410 Speaker Replacement, Speaker: 步骤 8 中的图像 3,3
    • Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off.
  9. Olympus Stylus 410 Speaker Replacement: 步骤 9 中的图像 1,1
    • Un-solder the wires to remove the speaker.
结论
团队
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G13
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,417
