跳转到主内容
Olympus Stylus 410 Slider Replacement
你所需要的
  1. Olympus Stylus 410 Slider Replacement, Slider: 步骤 1 中的图像 1,1
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Slider Replacement: 步骤 2 中的图像 1,1
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Olympus Stylus 410 Slider Replacement: 步骤 3 中的图像 1,1
    • Lift the slider up until it comes off the upper track.
  4. Olympus Stylus 410 Slider Replacement: 步骤 4 中的图像 1,1
    • The slider should now be free from the body of the camera.
结论
另外一个人完成了本指南。
Jared Ruekberg
于04/15/10注册
33 声望
创作了2篇指南
团队
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G13
5 名成员
创作了17篇指南
2条评论
Camera would not turn on nor lens extend. Took slider off per instructions and cleaned the switch and was able to rotate switch back and forth to turn camera on and off by hand. Reassembled slider and could turn camera on but not off. Disassembled again and find the rotating switch is permanently stuck in counter clockwise position and cannot be activated by hand. I do not want to force the switch because it did operate very easy. What can be the trouble?
rraff8300@sbcglobal.net
Richard Rafferty - 回复
Excellent instructions for removing stylist 410 slider. Hope you can help with my prior stuck switch problem.
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 34
总计 3,568
