跳转到主内容
Olympus Stylus 410 Shutter Button Replacement
你所需要的
  1. Olympus Stylus 410 Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 1,3 Olympus Stylus 410 Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 2,3 Olympus Stylus 410 Shutter Button Replacement, Shutter Button: 步骤 1 中的图像 3,3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Shutter Button Replacement: 步骤 2 中的图像 1,2 Olympus Stylus 410 Shutter Button Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  3. Olympus Stylus 410 Shutter Button Replacement: 步骤 3 中的图像 1,2 Olympus Stylus 410 Shutter Button Replacement: 步骤 3 中的图像 2,2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
结论
Rory Aronson
于04/15/10注册
46 声望
创作了6篇指南
团队
Cal Poly, Team 6-13, Maness Spring 2010 Cal Poly, Team 6-13, Maness Spring 2010 的会员
CPSU-MANESS-S10S6G13
5 名成员
创作了17篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 3,138
