跳转到主内容
Olympus Stylus 1030 SW Flash Assembly Replacement
你所需要的
  1. Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement, Flash Assembly: 步骤 1 中的图像 3,3
    • Remove the three screws in the corner of the front plate using a Phillips #00 screwdriver.
    • Lift up on the plate until it comes off the rest of the camera.
  2. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 2 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 2 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 2 中的图像 3,3
    • Use the Phillips #00 screwdriver to remove the two screws on both of the side plates of the camera.
  3. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera.
  4. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 4 中的图像 1,2 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 4 中的图像 2,2
    • Turn the camera so the short side without the av port is facing you.
    • Remove both of the screws on this side using the Phillips #00 screwdriver.
    • Remove the front case.
  5. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 5 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 5 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 5 中的图像 3,3
    • Face the camera so the short side with the AV port facing you. Use your Phillips #00 screwdriver to remove the single screw.
    • Turn your camera so the other short side is facing you. Use the Phillips #00 screwdriver to remove the two screws on the silver parts.
    • Face the bottom of your camera towards you and remove the single screw using the Phillips #00 screwdriver.
  6. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 6 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 6 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 6 中的图像 3,3
    • Open the battery door and use your Phillips #00 screwdriver to remove the screw in the middle of the opening.
    • Use the spudger to pry at the rear case until it comes off.
  7. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 7 中的图像 1,2 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 7 中的图像 2,2
    • Flip the camera so the front is facing you.
    • Use your Phillips #00 screwdriver to remove the three screws located in the corners on this side.
  8. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 8 中的图像 1,1
    • Turn the camera so you are looking at the top.
    • Use your Phillips #00 screwdriver to remove the single screw.
  9. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 9 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 9 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 9 中的图像 3,3
    • Use your spudger to gently pry at the side of the LCD screen and the cover over it.
    • Gently take it apart, using caution with the motherboard and battery.
  10. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 10 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 10 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 10 中的图像 3,3
    • Use your Phillips #00 screwdriver to remove the three screws.
  11. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 11 中的图像 1,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 11 中的图像 2,3 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 11 中的图像 3,3
  12. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 12 中的图像 1,1
    • Pull the foam to the side gently and use your Phillips #00 screwdriver to remove the single screw.
  13. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use your tweezers to gently pull the motherboard out of the camera.
  14. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 14 中的图像 1,2 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 14 中的图像 2,2
    • Use your Phillips #00 screwdriver to remove the two screws holding the wires to the flash assembly.
  15. Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 15 中的图像 1,2 Olympus Stylus 1030 SW Flash Assembly Replacement: 步骤 15 中的图像 2,2
    • Use your tweezers to gently remove the last wires connected to the flash assembly.
结论
Paige Asmus
于03/24/23注册
241 声望
撰写一个指南
团队
Casper College, Team 1-4, Lareau Spring 2023 Casper College, Team 1-4, Lareau Spring 2023 的会员
CASC-LAREAU-S23S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 60
