本指南有最近更改,您可查看未经巡查的最新版本。
简介
If you’re looking to replace a part of your Olympus Stylus 1030 SW Camera, you will most likely need to disassemble it first. This guide will help you accomplish that. Don’t worry, no special skills are required.
Before you begin disassembling, be sure to remove the SD card and the battery from the camera.
你所需要的
Using the iFixit Opening Tool, pry off the plastic part of the lens.
Using the T6 Torx screwdriver, unscrew the three screws.
即将完成!
结论
