跳转到主内容
Olympus Stylus 1010 Flash Replacement
你所需要的
  1. Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: 步骤 1 中的图像 1,2 Olympus Stylus 1010 Flash Replacement, Disassembling Olympus Stylus 1010 Case: 步骤 1 中的图像 2,2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Flash Replacement: 步骤 2 中的图像 1,1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Flash Replacement: 步骤 3 中的图像 1,2 Olympus Stylus 1010 Flash Replacement: 步骤 3 中的图像 2,2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Flash Replacement: 步骤 4 中的图像 1,1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Flash Replacement: 步骤 5 中的图像 1,1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Flash Replacement: 步骤 6 中的图像 1,3 Olympus Stylus 1010 Flash Replacement: 步骤 6 中的图像 2,3 Olympus Stylus 1010 Flash Replacement: 步骤 6 中的图像 3,3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Flash Replacement: 步骤 7 中的图像 1,3 Olympus Stylus 1010 Flash Replacement: 步骤 7 中的图像 2,3 Olympus Stylus 1010 Flash Replacement: 步骤 7 中的图像 3,3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Flash Replacement, Lens: 步骤 8 中的图像 1,2 Olympus Stylus 1010 Flash Replacement, Lens: 步骤 8 中的图像 2,2
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Flash Replacement: 步骤 9 中的图像 1,1
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Flash Replacement: 步骤 10 中的图像 1,2 Olympus Stylus 1010 Flash Replacement: 步骤 10 中的图像 2,2
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
  11. Olympus Stylus 1010 Flash Replacement, Motherboard: 步骤 11 中的图像 1,1
    • Remove the two Phillips #00 screws on the right side of the camera.
  12. Olympus Stylus 1010 Flash Replacement: 步骤 12 中的图像 1,1
    • Still using the spudger, detach the gold wire tape connectors from the motherboard.
  13. Olympus Stylus 1010 Flash Replacement: 步骤 13 中的图像 1,1
    • Desolder the upper right and lower left wires to remove the motherboard.
  14. Olympus Stylus 1010 Flash Replacement: 步骤 14 中的图像 1,2 Olympus Stylus 1010 Flash Replacement: 步骤 14 中的图像 2,2
    • In order to remove the motherboard, grab each side of it and pull up using your thumb and forefinger.
  15. Olympus Stylus 1010 Flash Replacement, Flash: 步骤 15 中的图像 1,3 Olympus Stylus 1010 Flash Replacement, Flash: 步骤 15 中的图像 2,3 Olympus Stylus 1010 Flash Replacement, Flash: 步骤 15 中的图像 3,3
    • Remove the two remaining Phillips #00 screws.
    • Lift the metal piece straight up to remove it.
  16. Olympus Stylus 1010 Flash Replacement: 步骤 16 中的图像 1,3 Olympus Stylus 1010 Flash Replacement: 步骤 16 中的图像 2,3 Olympus Stylus 1010 Flash Replacement: 步骤 16 中的图像 3,3
    • Pull gently on the white tab to remove the small motherboard with the flash device on it.
  17. Olympus Stylus 1010 Flash Replacement: 步骤 17 中的图像 1,2 Olympus Stylus 1010 Flash Replacement: 步骤 17 中的图像 2,2
    • Pull out the silver button using your thumb and forefinger.
    • Remove the small motherboard from the camera casing.
  18. Olympus Stylus 1010 Flash Replacement: 步骤 18 中的图像 1,3 Olympus Stylus 1010 Flash Replacement: 步骤 18 中的图像 2,3 Olympus Stylus 1010 Flash Replacement: 步骤 18 中的图像 3,3
    • Remove the plastic flash cover using a spudger.
  19. Olympus Stylus 1010 Flash Replacement: 步骤 19 中的图像 1,2 Olympus Stylus 1010 Flash Replacement: 步骤 19 中的图像 2,2
    • Remove the flash bulb using a plastic spudger.
结论
Curtis Reedy
于01/12/11注册
267 声望
创作了2篇指南
团队
Cal Poly, Team 13-4, Forte Winter 2011 Cal Poly, Team 13-4, Forte Winter 2011 的会员
CPSU-FORTE-W11S13G4
6 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,504
