跳转到主内容
Olympus SZ-12 Lens Replacement
你所需要的
  1. Olympus SZ-12 Lens Replacement, Back Case: 步骤 1 中的图像 1,2 Olympus SZ-12 Lens Replacement, Back Case: 步骤 1 中的图像 2,2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 Lens Replacement: 步骤 2 中的图像 1,1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 Lens Replacement: 步骤 3 中的图像 1,1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 Lens Replacement: 步骤 4 中的图像 1,1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 Lens Replacement: 步骤 5 中的图像 1,1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 Lens Replacement: 步骤 6 中的图像 1,1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 Lens Replacement, LCD Screen: 步骤 7 中的图像 1,1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 Lens Replacement: 步骤 8 中的图像 1,1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 Lens Replacement: 步骤 9 中的图像 1,1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
  10. Olympus SZ-12 Lens Replacement, Lens: 步骤 10 中的图像 1,2 Olympus SZ-12 Lens Replacement, Lens: 步骤 10 中的图像 2,2
    • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
  11. Olympus SZ-12 Lens Replacement: 步骤 11 中的图像 1,3 Olympus SZ-12 Lens Replacement: 步骤 11 中的图像 2,3 Olympus SZ-12 Lens Replacement: 步骤 11 中的图像 3,3
    • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
  12. Olympus SZ-12 Lens Replacement: 步骤 12 中的图像 1,3 Olympus SZ-12 Lens Replacement: 步骤 12 中的图像 2,3 Olympus SZ-12 Lens Replacement: 步骤 12 中的图像 3,3
    • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
  13. Olympus SZ-12 Lens Replacement: 步骤 13 中的图像 1,1
    • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
    • Remove the lens frame.
  14. Olympus SZ-12 Lens Replacement: 步骤 14 中的图像 1,3 Olympus SZ-12 Lens Replacement: 步骤 14 中的图像 2,3 Olympus SZ-12 Lens Replacement: 步骤 14 中的图像 3,3
    • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
    • Remove the lens.
结论
2等其他人完成本指南。
一条评论
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 22
总计 1,719
