跳转到主内容
Olympus SZ-12 LCD Screen Replacement
你所需要的
  1. Olympus SZ-12 LCD Screen Replacement, Back Case: 步骤 1 中的图像 1,2 Olympus SZ-12 LCD Screen Replacement, Back Case: 步骤 1 中的图像 2,2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 LCD Screen Replacement: 步骤 5 中的图像 1,1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 LCD Screen Replacement, LCD Screen: 步骤 7 中的图像 1,1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 552
