跳转到主内容
Olympus SP-320 Motherboard Replacement
你所需要的
  1. Olympus SP-320 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Olympus SP-320 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Olympus SP-320 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the 3 mm long screw using a Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Motherboard Replacement: 步骤 3 中的图像 1,2 Olympus SP-320 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Motherboard Replacement: 步骤 4 中的图像 1,3 Olympus SP-320 Motherboard Replacement: 步骤 4 中的图像 2,3 Olympus SP-320 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, white, plastic clip detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Motherboard Replacement: 步骤 5 中的图像 1,2 Olympus SP-320 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove 2 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
    • Remove 3 mm long screws with the Phillips head screwdriver that has a PH000 size bit.
  6. Olympus SP-320 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove motherboard.
结论
2等其他人完成本指南。
2条评论
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
Istvan Ujfalvi - 回复
It would be nice to know why you needed to access the motherboard.
John - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 13
总计 516
