跳转到主内容
Olympus SP-320 Back casing and LCD screen Replacement
你所需要的
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 步骤 1 中的图像 1,3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 步骤 1 中的图像 2,3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: 步骤 1 中的图像 3,3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: 步骤 2 中的图像 1,1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: 步骤 3 中的图像 1,1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: 步骤 4 中的图像 1,3 Olympus SP-320 Back casing and LCD screen Replacement: 步骤 4 中的图像 2,3 Olympus SP-320 Back casing and LCD screen Replacement: 步骤 4 中的图像 3,3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: 步骤 5 中的图像 1,3 Olympus SP-320 Back casing and LCD screen Replacement: 步骤 5 中的图像 2,3 Olympus SP-320 Back casing and LCD screen Replacement: 步骤 5 中的图像 3,3
    • You have detached the back casing and LCD screen.
结论
1指南评论
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 27
总计 794
