简介
Is your LCD Screen cracked or unresponsive? Use this guide to replace it and get back to taking awesome photos.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
你所需要的
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
Use tweezers to peel back the plastic cover.
Remove the LCD Screen.
There is more to it than shown here. You must remove the circuit board from the back of the old LCD screen, unplug those ribbon cables, transfer the circuit board to the new screen, and plug in the cables.
6等其他人完成本指南。
7条评论
Magnifico
Great Work!!
apuntotres - 回复
Where can I buy a replacement LCD screen?
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Same problem, stuck in selfie mode. Upside down display in normal mode. Hope somebody could help. Thanks!
Je rencontre le même problème d'image inversé. Pas trouvé de solution ailleurs pour le moment...
