跳转到主内容
Olympus OM-D E-M10 Mark II Screen Replacement
你所需要的
  1. Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 步骤 1 中的图像 1,2 Olympus OM-D E-M10 Mark II Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Lay the camera on its back as shown. Using the button located to the right of the lens, hold it down while rotating the lens to release it from the camera.
  2. Olympus OM-D E-M10 Mark II Screen Replacement: 步骤 2 中的图像 1,1
    • Extend out the screen so you can reach the screws. Remove the a total of four screws using a Phillips #00 at the top and the back of the screen.
    • This step has two types of screws. (2x) 3.5 mm on the top, (2x) 1.7 mm on the back.
  3. Olympus OM-D E-M10 Mark II Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the screen away from the base of the camera. Then disconnect the cable connectors from the circuit board. Be sure to remove the smaller circuit board with care.
  4. Olympus OM-D E-M10 Mark II Screen Replacement: 步骤 4 中的图像 1,1
    • Separate the screen from the camera. Now you are able to install your replacement screen
结论
另外一个人完成了本指南。
Connor Langguth
于09/03/19注册
346 声望
创作了2篇指南
团队
IUPUI, Team S1-G5, Hovde Fall 2019 IUPUI, Team S1-G5, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G5
3 名成员
创作了5篇指南
4条评论
Hi, do you know if the LCD screen from the Mark II is the exact same as the Mark III? I see replacements for the Mark II being sold, but they don’t say whether they’re compatible.
Solomon Krause-Imlach - 回复
Hey Solomon I am experiencing the same issue. Did you find out if they are exactly the same?? My LCD screen no longer functions and all I come across online is the Mark II LCD's.
Zacharia Gupta -
Hi, do you know where I can buy the screen?
Thanks
Lorenzo
Lorenzo Zaccarini - 回复
If you order only panel like me, theres few wery scary parts more. You have to remove couple pcb's, trying get connectors back in and you definetly need elastic glue for glueing screen back.
Mikko Hyvärinen - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 53
过去 30 天: 216
总计 10,527
