跳转到主内容
Olympus OM-D E-M10 Mark II SD Card Replacement
  1. Olympus OM-D E-M10 Mark II SD Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
    • To ensure that the battery door is properly in the closed position, listen for an audible click.
  2. Olympus OM-D E-M10 Mark II SD Card Replacement: 步骤 2 中的图像 1,1
    • Move the dark red latch towards the direction of the camera lens to release the battery from the camera.
    • Make sure the dark red latch blocks the battery from moving after placing the battery in the camera during reassembly.
  3. Olympus OM-D E-M10 Mark II SD Card Replacement: 步骤 3 中的图像 1,1
    • You can now remove the battery from the body of the camera and begin reassembly with your new battery.
  4. Olympus OM-D E-M10 Mark II SD Card Replacement, SD Card: 步骤 4 中的图像 1,1
    • Find the SD card located near the hinges of the door and gently press down on it so that it becomes free.
  5. Olympus OM-D E-M10 Mark II SD Card Replacement: 步骤 5 中的图像 1,1
    • Remove the SD card from the camera by grabbing it with your fingers and lifting away from the camera.
结论
To add your new SD card to your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Channing Pezet
于02/14/18注册
214 声望
创作了2篇指南
团队
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 17
过去 30 天: 42
总计 2,715
