跳转到主内容
Olympus OM-D E-M10 Mark II Lens Replacement
  1. Olympus OM-D E-M10 Mark II Lens Replacement, Lens: 步骤 1 中的图像 1,1
    • Press the black button located to the right of the camera lens when facing the front of the camera.
  2. Olympus OM-D E-M10 Mark II Lens Replacement: 步骤 2 中的图像 1,1
    • Grasp the innermost ring on the lens, closest to the camera body, which can be located by the small red dot. This is the only ring that should not turn, unless the button specified in the previous step is held down.
  3. Olympus OM-D E-M10 Mark II Lens Replacement: 步骤 3 中的图像 1,1
    • While holding down the button specified in step 1, begin turning the inner most ring, specified in step 2, counterclockwise until the camera lens becomes free from the camera body.
  4. Olympus OM-D E-M10 Mark II Lens Replacement: 步骤 4 中的图像 1,1
    • Once the lens is free from the camera body, pull the lens completely away from the body to make sure the lens is truly free.
结论
Channing Pezet
于02/14/18注册
214 声望
创作了2篇指南
团队
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G6
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 55
总计 3,886
