跳转到主内容
Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement
你所需要的
  1. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement, HDMI and Multi-connector Cover: 步骤 1 中的图像 1,1
    • There are three different types and lengths of screws used to hold the bottom plate of the camera. Make proper note of each screws original position during your disassembly.
    • Using the PH00 Phillips-head screwdriver, unscrew the two 1/3 inch screws with silver threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/3 inch screws with blue threads from the the bottom of the camera.
    • Using the PH00 Phillips-head screwdriver, unscrew the three 1/2 inch screws with silver threads from the the bottom of the camera.
  2. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 步骤 2 中的图像 1,1
    • After removing all of the screws, remove the bottom plate from the camera to continue.
  3. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 步骤 3 中的图像 1,2 Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 步骤 3 中的图像 2,2
    • Continuing to use the size PH00 Phillips-head screwdriver, remove the two 3/5 inch screws revealed after removing the bottom plate of the camera.
  4. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 步骤 4 中的图像 1,1
    • Open the HDMI connector door and continue to use the PH00 Phillips-head screwdriver to remove the 3/10 inch screw located underneath the door.
  5. Olympus OM-D E-M10 Mark II HDMI and Multi-connector Cover Replacement: 步骤 5 中的图像 1,1
    • Proper removal of all 11 screws listed in the steps above from the camera gives the camera the ability to be opened slightly and allows for the door to be lifted off of the hooks holding it in place within the camera.
结论
To add your new HDMI connector door, follow these instructions in reverse order.
Allen Anjal
于09/27/16注册
320 声望
创作了2篇指南
团队
USF Tampa, Team S5-G6, Eyestone Spring 2018 USF Tampa, Team S5-G6, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S5G6
4 名成员
创作了10篇指南
一条评论
so, where can I buy the port cover or door for the OMD-em10 mark2? Thanks
Raffy Martinez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 36
总计 2,800
