跳转到主内容
Olympus FE-210 Lens Assembly Replacement
你所需要的
  1. Olympus FE-210 Lens Assembly Replacement, Battery: 步骤 1 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement, Battery: 步骤 1 中的图像 2,2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Olympus FE-210 Lens Assembly Replacement: 步骤 2 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 2 中的图像 2,2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement, Front Casing: 步骤 3 中的图像 3,3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement: 步骤 4 中的图像 3,3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Olympus FE-210 Lens Assembly Replacement, Rear Casing: 步骤 5 中的图像 1,1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 1,3 Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 2,3 Olympus FE-210 Lens Assembly Replacement: 步骤 6 中的图像 3,3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Olympus FE-210 Lens Assembly Replacement, Motherboard: 步骤 7 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement, Motherboard: 步骤 7 中的图像 2,2
    • Remove the 2 pieces of translucent yellow tape.
    • Removing these pieces of tape will void the camera warranty. They serve no functional purpose and do not need to be replaced during reassembly.
  8. Olympus FE-210 Lens Assembly Replacement: 步骤 8 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 8 中的图像 2,2
    • Remove the seven 2.7 mm using a #00 screwdriver.
  9. Olympus FE-210 Lens Assembly Replacement: 步骤 9 中的图像 1,1
    • Remove the ribbon cord located near the top right corner of the motherboard. Do this by carefully pulling the cord out of the socket using a pair of tweezers.
  10. Olympus FE-210 Lens Assembly Replacement: 步骤 10 中的图像 1,1
    • Disconnect the ribbon cord located on the left side of the motherboard.
    • Use tweezers or a spudger to lift the latch on the connector.
    • Carefully remove the cord from the connector.
  11. Olympus FE-210 Lens Assembly Replacement: 步骤 11 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 11 中的图像 2,2
    • De-solder the 2 connection points.
    • Be careful to not damage any part of the circuit board with the soldering iron.
  12. Olympus FE-210 Lens Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the motherboard from the camera casing.
  13. Olympus FE-210 Lens Assembly Replacement, Lens Assembly: 步骤 13 中的图像 1,1
    • Remove the three 3.6 mm screws using a #00 screwdriver.
  14. Olympus FE-210 Lens Assembly Replacement: 步骤 14 中的图像 1,2 Olympus FE-210 Lens Assembly Replacement: 步骤 14 中的图像 2,2
    • Slide the lens to the left and pull up. The lens should easily come loose and slide right out.
结论
Matt
于01/25/11注册
811 声望
创作了6篇指南
团队
Cal Poly, Team 4-36, Regan Winter 2011 Cal Poly, Team 4-36, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G36
3 名成员
创作了14篇指南
一条评论
This is also applicable to the Olympus FE170. I dismantled and repaired mine using this guide. Excellent!
Alan Shaw - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 22
总计 6,191
