跳转到主内容
Olympus D590 Motherboard Replacement
你所需要的
  1. Olympus D590 Motherboard Replacement, Face Plate: 步骤 1 中的图像 1,1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Motherboard Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Motherboard Replacement: 步骤 7 中的图像 1,1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,1
    • Remove four screws holding the motherboard to the internal housing component using a Phillips #1 screwdriver.
  9. Olympus D590 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Be cautious of the wires attached to the motherboard.
    • Remove the motherboard from the internal housing component.
    • Do not completely lift the motherboard out with the wiring connected. The wires must be disconnected before proceeding. The next step will demonstrate disconnection process.
  10. Olympus D590 Motherboard Replacement: 步骤 10 中的图像 1,3 Olympus D590 Motherboard Replacement: 步骤 10 中的图像 2,3 Olympus D590 Motherboard Replacement: 步骤 10 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use rounded tweezers to disconnect the three wiring strips from the motherboard.
    • Using sharp tweezers may tear wiring tape and wires.
    • Use gentle force when wiggling or pulling wiring tape and wires to disconnect from the motherboard.
结论
2等其他人完成本指南。
Sara
于04/15/10注册
84 声望
创作了2篇指南
团队
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G23
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,792
