跳转到主内容
Olympus D590 Backplate Replacement
你所需要的
  1. Olympus D590 Backplate Replacement, Face Plate: 步骤 1 中的图像 1,1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Backplate Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Backplate Replacement: 步骤 3 中的图像 1,1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Backplate Replacement: 步骤 4 中的图像 1,1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Backplate Replacement: 步骤 5 中的图像 1,1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Backplate Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Backplate Replacement: 步骤 7 中的图像 1,1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Backplate Replacement, Backplate: 步骤 8 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
  9. Olympus D590 Backplate Replacement: 步骤 9 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
  10. Olympus D590 Backplate Replacement: 步骤 10 中的图像 1,1
    • Using an iFixit opening tool, pry the backplate from the camera internal housing component.
  11. Olympus D590 Backplate Replacement: 步骤 11 中的图像 1,1
    • Pull the backplate away from the camera internal housing component.
结论
Katie
于04/15/10注册
31 声望
创作了3篇指南
团队
Cal Poly, Team 28-23, Regan Spring 2010 Cal Poly, Team 28-23, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G23
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,060
