跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Olympus Camedia D560 Rear Panel Control Buttons Replacement
你所需要的
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: 步骤 1 中的图像 1,2 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: 步骤 1 中的图像 2,2
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 2 中的图像 1,2 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 2 中的图像 2,2
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 3 中的图像 1,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 3 中的图像 2,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 3 中的图像 3,3
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 4 中的图像 1,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 4 中的图像 2,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 4 中的图像 3,3
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 5 中的图像 1,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 5 中的图像 2,3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: 步骤 5 中的图像 3,3
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 7
总计 1,015
