简介
If your battery cover is damaged, your battery may suffer damage from heat, cold, liquids, or other objects entering the battery compartment. This guide will demonstrate how to remove the battery compartment cover so you are able to replace it.
你所需要的
Remove all five screws found on the outer shell of the camera.
Three along the bottom
Two on the side closest to the LCD screen
You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well.
Once all screws are removed, use a blue prying tool to carefully pry the back outer shell away from the rest of the camera.
Completely separate the back cover from the rest of the camera. Set the back cover aside.
Remove four screws from the front outer cover of the camera.
Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
To remove the yellow and black wires, gently unplug the end of the wire connected to the inner casing of the camera.
The front outer cover should now be completely separated from the rest of the camera.
