跳转到主内容
修复你的物品
维修的权力
商店
配件
没有特定配件。
  1. Remove all five screws found on the outer shell of the camera. You will find three along the bottom (see picture #1) and two more up one side (the side closest to the LCD screen). You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well. Once all screws are removed, use a blue iPod opening tool (seen in picture #3) to carefully pry the back outer shell away from the rest of the camera.
    • Remove all five screws found on the outer shell of the camera. You will find three along the bottom (see picture #1) and two more up one side (the side closest to the LCD screen).
    • You will find three more under the USB port flap and one more under the memory card flap. Remove these four as well.
    • Once all screws are removed, use a blue iPod opening tool (seen in picture #3) to carefully pry the back outer shell away from the rest of the camera.
  2. Completely separate the back cover from the rest of the camera. Set the back cover aside. Remove 4 screws from the front outer cover to the camera (see image #2 for screw locations). Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
    • Completely separate the back cover from the rest of the camera. Set the back cover aside.
    • Remove 4 screws from the front outer cover to the camera (see image #2 for screw locations).
    • Use a Spudger to pry the front outer cover away from the camera. Do this gently to avoid damaging the yellow and black wires connecting the front outer cover to the camera.
  3. Unplug the yellow and black wires connecting the front outer cover of the camera to the rest of the camera, as shown in image #2. This can be done by gently unplugging the end of the wire connected to the inner casing of the camera. The front outer cover should now be completely separated from the rest of the camera. The front outer cover should now be completely separated from the rest of the camera.
    • Unplug the yellow and black wires connecting the front outer cover of the camera to the rest of the camera, as shown in image #2. This can be done by gently unplugging the end of the wire connected to the inner casing of the camera.
    • The front outer cover should now be completely separated from the rest of the camera.
  4. Carefully set aside the front outer cover of the camera. Then, locate the two screws attaching the battery compartment cover to the rest of the camera (see picture #2). Remove the 2 screws attaching the battery compartment cover to the rest of the camera. Once both screws are removed, the back hinge of the battery compartment cover will flip up (see picture #3).
    • Carefully set aside the front outer cover of the camera. Then, locate the two screws attaching the battery compartment cover to the rest of the camera (see picture #2).
    • Remove the 2 screws attaching the battery compartment cover to the rest of the camera.
    • Once both screws are removed, the back hinge of the battery compartment cover will flip up (see picture #3).
  5. Your battery compartment cover should now be completely removed and ready for repair or replacement.
    • Your battery compartment cover should now be completely removed and ready for repair or replacement.
结论
GradStudents2011
于2011年09月08日注册
21 信誉积分
创作了3篇指南
团队
can someone , please, show me how to replace or repair the flashlight of this camera? mine stopped working.
thank you, hendrik
olé kike - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 3
总计 1,219
