跳转到主内容
Olympus C-765 Motherboard Replacement
你所需要的
  1. Olympus C-765 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Olympus C-765 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Olympus C-765 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
    • Remove the two 2mm screws from the left side panel.
    • Remove the single 3mm screw from the right side panel.
    • Remove the five 3mm screws from the bottom of the camera.
  2. Olympus C-765 Motherboard Replacement: 步骤 2 中的图像 1,2 Olympus C-765 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Rock the two ribbon cables gently out of their sockets.
    • For more on disconnecting ribbon cables, look here.
    • Grasp and pull the white cable out of its clip with metal tweezers.
    • Remove the back panel completely.
  3. Olympus C-765 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Peel off the black plastic sheets.
    • Use the Phillips #00 screwdriver to remove the two 3mm screws holding the motherboard in place.
  4. Olympus C-765 Motherboard Replacement: 步骤 4 中的图像 1,2 Olympus C-765 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon cable directly below the viewfinder.
    • Detach the white plastic clip from its socket with a pair of tweezers.
    • Disconnect the ribbon cable from the center of the board, near the central hole.
    • Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
    • For more information on disconnecting ribbon cables, look here.
  5. Olympus C-765 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the single 3mm ground screw attached to the right side of the camera body using the Phillips #00 screwdriver.
  6. Olympus C-765 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Use the soldering iron to desolder the connections from the motherboard.
    • For more information on desoldering, look here.
    • When soldering, avoid touching any of the other components with the soldering iron to prevent damage to the motherboard.
  7. Olympus C-765 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the motherboard from the camera.
结论
Mason Morgan
于04/05/11注册
115 声望
创作了6篇指南
团队
Cal Poly, Team 12-33, Maness Spring 2011 Cal Poly, Team 12-33, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G33
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,342
