跳转到主内容
Olympus 850SW Memory Card Replacement
  1. Olympus 850SW Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,1
    • Locate the memory card latch/ battery latch on the bottom panel of the camera and open it.
    • Make sure to remove the battery before trying to remove the memory card.
  2. Olympus 850SW Memory Card Replacement: 步骤 2 中的图像 1,1
    • Hold the memory card so that the pointed wedge is facing up and the sticker is facing the front of the camera.
  3. Olympus 850SW Memory Card Replacement: 步骤 3 中的图像 1,1
    • Hold the card so that the thicker end of it is to the right, and the flat end is facing the bottom of the camera.
    • Insert the card into the compartment fully until it clicks into place.
  4. Olympus 850SW Memory Card Replacement: 步骤 4 中的图像 1,1
    • Close the memory card latch/ battery latch.
结论
另外一个人完成了本指南。
一条评论
How much gigabytes can I use on an Olympus 850 SW?
Yuan - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 50
总计 1,685
